Mikrokopter MK gimbal control horizon/roll tweak
A few weeks ago I was reading someone's thread about PID tuning in MKtool. It got me thinking about the gyro settings and maybe getting better camera control so I started going through the different pages of the MK wiki and MKtool. After a few hours of tweaking the different settings I thought I had it set up pretty well but with a little wind today it flew very poorly. Not having time to play with it too much I reset everything back to factory settings except for one setting that I think makes a huge difference. That setting is in the Gyro page of MKtool
http://www.mikrokopter.de/ucwiki/en/MK-Parameter/Gyro
and it is the ACC/Gyro Comp. Best as I can tell, it is a translation of lateral movement (as sensed by the accelerometers) into a rotational movement and something the FC will respond to with roll if you want it to. Where you see this in the camera movements is the very dodgy ability of the Mikrokopter FC to hold a camera/horizon level during extended sideways flight. If you hold your helicopter and roll it left or right, the camera will initially stay pretty close to level. If you then make a quick lateral movement, without rolling into or out of the previous position, you'll see the camera mount respond by rolling into the bank the helicopter is already in. In video this apperas as if the mount has insufficient roll compensation and if you try to fix it by increasing compensation it just makes the camera seem nervous and out of control.
The ACC/Gyro Comp factor in MKtool is applied inversely meaning the larger the number, the smaller the response. With a very large number, the FC won't let lateral movements be misinterpreted as rolling motion and the camera mount will settle down and hold level much better. I've got mine set to 110 at the moment and the results are very different from the usual crooked horizon problem we've all experienced. The camera has enough compensation to make the pure roll movements nearly invisible and in lateral movements the camera only adjusts a very small amount.
It says in the wiki "this setting can also effect the performance of the gimbal compensation" but if you're not in that page looking for it you'll never find it.
Bart
Craig,
The video was taken in my front yard and it just showed too much of the area around my house and made me a little uncomfortable. I just got back from shooting video of a car dealership so I'll sort through it later and post something. I think my batteries were having a tough time today in the high temps and humidity but it was also possible that the value i suggested to improve roll control also makes the helicopter a little more skittish close to the ground where the helicopter is flying in its own wash, aka ground effect.
I'm going to take a little break this afternoon but maybe I'll be able to get something together before heading to bed later.
Bart
anaka
ok Bartman, I just had some flights with these new settings, the main sensation is that stability is increased, the flight is smoother and the stick is less sensible, so you have to use wider stick movements
during the flight I had 8mph wind gasps and the MR is more sensitive to wind, it drifts more but doesent start to woble
the camera stabilization is a bit better as well, in the moments withut wind I can see very smooth movements
