How come my quad seems to fly much better with 8x4.5 vs 10x4.5 (or5).
Way less wobbles & bobbles.
EVERYTHING else is identical, including the 3S batteries.
I'm so confused.
:upset:
You deffinently need to adjust the gains when changing props. If you dont change any gain settings, then the copter will certainly feel different. If you have not touched the gains, then that is your problem.
OK thanks for that info.
So...generally speaking, and assuming EVERYTHING is identical except for the props, going from an 8 to a 10, do the gains increase (higher value) or decrease (lower value)>
Well for me i had to go my basic gain settings with 8" props was pitch 195 roll 195 yaw 195 vertical 120. With the 10" props my settings for pitch 250 roll 250 yaw 250 vertical 110. Hope this helps.
