DJI F550 with Wookong-M 3S Battery Which BLADES?
VINHEX
Hi I've just setup my F550 and I'm using a 3S Battery does anyone use the 10" Props on this setup? What are the benefits of using these apart from more lift capacity?
I've heard if you run 10" with a 4S Battery you could burn out the standard motors.
Vin
Topper
3S and 10" Props is fine. Don't try 8" with 3S on the F550 the weight is too hight, so the motors will be very hot and it will fly ugly in the wind.
VINHEX
Thanks Topper, was using the 8" but only run 3 test flights might answer a lot of tweeking questions.
Vin
VINHEX
What blade size do you recommend, 10x5 10x6 10x7 10.5x? ect. I've also sent a message to DJI saying that I've heard lots of information about there 10" props failing.. Will be interesting to see what they come back with.
