Update on my Mikrokopter FC issues
I've been trying to play with the firmware update and EEPROM refresh to get the I2c error on my FC to clear. THis has been without a power board hooked up. It appears that somewhere on the FC is a switch that registers the presence of the power board, probably when the I2c circuit is closed. That switch appears to be stuck in the closed position and the FC is looking for the power board even when it isn't hooked up. I believe that this is what is causing the I2c error but I wouldn't know which little SMD to replace on the FC to fix it.
When this problem started I began to look for the I2c error on the power board without thinking it was possibly on the FC. I pulled all the I2c jumpers BL by BL expecting to find the one that would clear the I2c error. That didn't happen though and when it finally occurred to me to hook up the FC to MKtool without the power board, I saw that the I2c error was being generated by the FC.
So last night, after playing with the FC for a little while I decided to get the power board all put back together and see if the I2c error would clear once the FC had a closed I2c circuit again. With full Lipo power and a good power board attached, the FC is once again giving a green light for the BL's. WIthout the power board it still generates an error.
I'm thinking it's safe provided I don't fly without the power board hooked up.
Anyone care to agree or disagree?
Bart
