Wookong Failsafe problem
Hi!
I tried Failsafe today on my F450 Wookong and Turnigy 9x FrSky. I turned off the tx and the MC made a quick descent, hit the ground, took a jump or two until it fell over. The motors were not shut off.
I could repeat the procedure
The MC should have ascent, gone home and landed.
What have I missed?
quadcopters
When you set up the failsafe it seems by the symptoms described that you did not set the Throttle failsafe value at over 10% throttle .
You need to make sure in assistant software before flight that when testing failsafe , the throttle moves over to the right at least 10% and also the flight status changes to failsafe.
Geoff
Geoff
Thanks, I'll check into that!
Thanks, Geoff!
We made quite a progress! When we switch to failsafe MC descends 1 metre or so before it ascends and start to go home. It makes a tough landing and motors are not turned off.
Suggestions?
