dolby
Needs more bacon!
Only 3 or 4 motors will spin when I ARM the WKM. If I unplug the power and plug it back in same thing will happen but different motors will spin up. One time after trying a dozen times all 6 motors spun up but power cycling it went back to its old tricks.
Motors: Avroto 2814 (the older ones with the stickers on the bell)
ESC: DYS 30amp flashed with simonk firmware.
(I set the throttle end points on each esc after flashing them)
Props: 12x6 APC
Any suggestions? I've read a few of you are using DYS 30a w/ simonk, Avroto and WKM with out issue.
Props: 12x6 APC
