Stuttering motor
pal72
Hi, I have a F450 naza. it works fine with 3S batteries. But when i tries a 4S battery one of the motors starts stuttering.. The rest of them is working fine. And all is fine with a 3S battery.
Can anybody help me with this problem
Regards Pål Åge Røstad
Tomstoy2
Sounds like a motor timing issue. Go into all your esc's and change the timing one level higher and see.
fayrwerks
got the same problem on mine... i havent tried it on 4s but on 3s 1motor is always stuttering but on mid throttle and on regular flight/hover no problem at all...
Tomstoy2... How to you go into the DJI timing?
pal72
now i have the problem with the 3S battery as well.... It all started when i tried the 4S battery, maybe i killed it? :)
Tomstoy2
Swap the motor over to another esc, see if it follows the motor. This will tell you if the motor is the issue, or the esc. If it follows the motor to the other esc then the motor is bad.
Unfortunately, this happens sometimes with DJI motors. I do not know who makes the motors for DJI, but it's a shame that so many posts are like yours.
I suspect this is why DJI went with a different size. Too bad they didn't go with a better proven manufacturer.
I don't use DJI motors, I started with Tiger motors and have been totally satisfied with them. A top quality motor without the high price tag as other quality motors.
Be forwarned, you can not mix and match motors.
pal72
After som swapping back and fourth.... i think it is the motor witch is the problem yes... thx Tomstoy2
Tomstoy2
I would just call the dealer you bought it from and tell him you have a problem with it. He should just send you out a replacement. They usually are pretty good about that. If not, then you know where you stand with them.
fayrwerks
Thank you, contacted FoxtechFPV showed the the video... replacing the motor... and gotta say its a bummer that i will have to wait for the mail to arrive... but Kudos to foxtech - great costumer support...
