DJI Wookong Multi-Rotor with Herkules ESC ?
fritz99
Hello !
Is ist possible to control the motors of a HEXA Copter with the Herkules II V4 ESCs ?
If yes, how can they be connected to the Wookong Controller ?
Fritz
You will need two Herkules boards.
M1,M3,M5 on Herkules A. M2,M4,M6 on Herkules B.
Easy...
Or you could use some regular esc's reflashed and save 1k.
fritz99
Easy...
ok !
Thank you.
But what I do not understand is how the two Herkules are connected to the Wookong Controller ?
The Herkules just has one connector with I2C bus ?
fritz99
Hello !
I have one more question :
I have programmed the firmware on the Herkules.
I have connected a motor to the Herkules.
I have made the ppm cable and connected it to an output of a receiver channel.
When I move the stick nothing happens with the motor. It does not start.
What do I have to do so that the motor will start ?
Fritz
Does the Herkules make the startup sound and do the lights come on? If so maybe you need to arm the motors as per DJI manual.
