Matts PVC Quad & Naza Controller
mattsPVC
Looks like I broke a blade mid flight, on the left front arm. Which caused excessive vibration in that arm, which in turn caused the screws to come loose holding that arm to the main body.
End result:
The arm fell out but was not broken.
Only two broken props.
No Damage to the PVC Frame or components.
mailman35
cool! :p
let me know when you get the L bracket info so i can start lookin for it :p
edit: scratch that, found the link you added just need to know where to order them from.. :O
and if i can find them in the US.
mattsPVC
mailman35
matt,
cool
like i said my problem is now just locating a source in the states to get them shipped from or buy them from. :O
mattsPVC
Here is a approx. cost.
FPV-PVC Quadcopter Build:
Dji Naza Controller $230
4x Motors @ $25 Each = $100
4x ESC @ $20 Each = $80
10x4.5 propellers @ $12 a set (Need plenty)
Parts to Build Quad = $30
3s 3000mah Battery $15 Each (Need at least 3)
A good battery charger $100
Sub Total Approx. $600
FPV Gear:
FPV Camera $100 (Could eliminate this if you use Gopro as FPV)
Video Transmitter $50
Video Receiver $50
Fatshark Video Goggles $250
3s 500mah Battery $5 (For Transmitter)
3s 2200mah Battery $15 (for Reciever)
Sub Total $470
Tx & Rx From $200-$500 ( I'm Using a JR DSX9. @ $500, Overkill)
Grand Total Approx. $1250-$1500
