setting up wookong
diverdan
I am having problems setting up the wookong.
The software wont allow me to change the control mode switch. It is set at A. and the slider wont move. It say the MC output is off.
Dan
Sar
Hi Dan, have you set up a Wookong before or is this your first time around? Can you mention a bit more about how you have the WK wired to the R/C Receiver? You should have an Aux channel wired to the U port(on my Spektrum Rx it's the 'gear' channel (channel 5). If the WK unit is receiving a signal from the receiver on that port it should show a blue block somewhere along the GPS-FAILSAFE-ATTI-FAILSAFE-M line. If it's not receiving a signal those blocks above the U line will all be grey. Double check the wiring for ground, power and signal line?
MC Output Off is normal when you're connected to the WKM, it means the motors are disabled.
Sar
Ah alright, well I don't have the experience in s.bus to help out there too much, I know on s.bus channel 7 is used for the flight mode switch but that's about it.
diverdan
Hi Sar
This is the first time i have set it up.
I have the motor turning, and they seem to be set up fine. But not the GPS. As Ross says, it is set into the s-bus output.
Also can get the gimble to work.
