PMU Unit with AfroPower Board
rwilabee
I'm just wondering when you use the AfroPower Board with your WKM if you are soldering your PMU directly to the board or still using the yellow connector.
Rich
Gunter
Draganflyer X4
I soldered cables to the board with the opposite yellow connector, then plugged the PMU into that. That way you can disconnect it easily.
Regards,
Gunter.
rwilabee
Makes sense I'll do it the same way.
Rich
Regards,
Gunter.
