MombasaFlash
Heli's & Tele's bloke
Following recommendations a few weeks ago to switch to 5S packs on a fairly bog standard AD-8 HLE with AXI 2814/22's to reduce temps and increase flight times, and on the very point of ordering some 5S packs, I decided I had better do a quick eCalc check. First I entered all the details with the 4S cells that I normally use, just to see the resulting calculated flight time in order to verify I had entered everything more or less correctly, and then simply change 4S to 5S.
Big warning in red saying over the limit ... motors will overheat ... blah, blah
So much for the 5S recommendation for the AD-8 methinks.:dejection:
Then, just for kicks, I enter in all the stuff for the bog standard MK Octo with its ROXXY 2827-35 motors and the same flat 4S cells it has always used without complaining and there is a big red warning saying 'max power over the limit of the motor'.
Huh?
According to eCalc it has to have 3S LiPo's ! ?
So I am back to square one. I have no idea whether it is safe to use 5S packs with a standard AD-8HLE or not.
DW AD-8 - 4S
DW AD-8 - 5S
MK Octo - 4S
Huh?
DW AD-8 - 4S
DW AD-8 - 5S
MK Octo - 4S
