Hi I hope someone can help I've been doing all sorts of searches and find similar, but not exact problems I'm experiencing.
I built a WK-M on an F450 frame. The motors are are Turnigy Air 2215Js (900kV/200W) and the ESCs are Turnigy Super Brain 40A (8kHz PWM, Gov Off, Fast Start, LVC 5.0, Insensitive Overload protection) *I ordered some plushes, but they're on a month long back-order* with an AR7000 Spektrum Receiver on a Futaba 9CHP w/Spektrum module. Battery is 3S/2200mAh. Props are GemFan 10x4.5.
The IMU is mounted dead center and aligned forward, and securely, on the top plate of the F450 with thin 3M foam (2mm?) and no physical contact with any other equipment. IMU wiring is not tensioned and does not pull on the IMU. The GPS is mounted on the medium length pole over front left bolt holes of the F450 frame and aligned forward. Motor rotation was verified against the manual multiple times. The frame has been balanced front/back/left/right.
I set up the motor enable to intelligent mode. In manual flight mode I move the sticks for intelligent start, the motors start. I fly around, I land(throttle all the way down) and the motors run until I do the intelligent stick move to stop. In Atti mode I have to do the intelligent stick move to start the motors, but I notice (on the ground fortunately) that if I pull the stick down below 10% the motors turn off by themselves(!?) This is weird as I expected intelligent mode on the motor start/stop to be the same in all modes. Is this normal?
As for the wobble. Originally I had a lot of wobble in manual mode, this cleared up once I connected the pitch and roll to the remote gain knob. The gain is at 60 percent right now, at 100% it was very wobbly, but OK I got it mostly stable in manual. When I switch to atti it's completely different and gets a substantial wobble, though it's still flyable the wobble grows in amplitude then settles back down then grows again. I'm not sure what's going on that would cause a huge difference between atti and manual mode or what specifically I should be looking at. I remounted the IMU just in case with no difference. In Atti mode I was getting two white flashes on the LED(and 1 and 2 yellow)
If anyone has some ideas on what's going on here I would appreciate hearing them. I'm scratching my head right now.
