Hello, I will try my best as i am not english speaker.
I have been reading this forum for some time and it has been really helpfull but i need something more.
I have upgrade my servos to Hitec but later i upgrade it again to a savox 1258 in tilt and one hitec 5245mg in roll and then start the problems
I try to conect it trough a ubec, but it does not work. (getting only the signal from the FC)
i put the servos directly to the FC and it works correct but suddenly the hitec stop and run.
I run only the savox and it is ok
run only the hitec and it is ok
conect both together again and after a few seconds it does not work. As I thought that the RECOM could be no enough y try again with the bec but it does not work at all, actually the servos does not move.
i have change the hitec to another simple one, like a futaba 3003 or bluebird 380 max and it works properly.
Any one knows what happend
If you need me to explain something better i will try again
Thankyou for this and for all the information i have got from this forum
Roberto
Roberto
