Mikrokopter Upgrade MK Robbe ROXXY 2827-35 to 8mm shaft for Graupner props
ZAxis
I want to fit Graupner 10x5 props to our MK Hexa2 to replace the existing MK supplied ones.
The Graupners have an 8 mm bore but the motors will only take 3mm bolts so I need to source adaptors or replacement shafts in the UK.
Can anyone recommend where to get them ?
andy
andy
You will need both a replacement prop shaft ( https://www.mikrocontroller.com/ind...id=466&zenid=8c0249db8348e752d34b640b402d4ee4 ) and a prop adaptor ( http://www.electricwingman.com/graupner/propeller-hub-spacer/8mm/5mm.aspx ).
You can either order the adpators direct from MK in Germany or check the list here for a UK based dealer ( https://www.mikrocontroller.com/index.php?main_page=partnershops )
Electricwingman is Uk based and stocks most of the Graupner props and adaptors, I usually order mine from there since Graupners are hard to find in the USA.
J.T.
Spiralling out of control
Andy,
Electricwingman do the inserts for the E-props. I got some 8mm to 5mm adapters from them.
ZAxis
Thanks for leads guys
I was going to talk to ElectricWingMan but just wanted to check for any alternatives
andy
