Now that I have the small APV quad flying under a Naza controller, the next step of the project was to swap out the Mk stack on the Droidworx AD6 for the WKM I removed from the quad. Yesterday I spent the better part of the day performing the transplant surgery and just before dark I was able to make the first flight of the AD6 with the WKM in control. I have to say in the year I've had the AD6 flying it has never flown this smooth or stable, the difference between the Mk and WKM flight control systems is very noticeable. The other thing I noticed is the AD6 doesn't seem to be plagued by the slight wobble that the larger hex I have used a WKM on had, from what I've been able to see of the AD6 in flight so far is that it's rock steady and looks like it's going to be a great platform for APV, better than it has been so far.
One minor problem to be sorted before I can get it out to a field and really fly it, after the seccond flight the #4 motor lost a phase when I went to start the motors. Initially I though it was an ESC so I swapped it out only to have the problem return as soon as I got outside to test fly. It appears to be an intermittent problem with either the wiring between ESC and motor or in the motor itself. In any case it won't be leaving the ground until it's 100% sorted as in in flight failure is not something I want to deal with. I have a set of Avroto sitting idle at the moment and that may become the fix, problem is they aren't the short shaft version which is what he Droidworx frame requires, so to use them they all have to come apart so I can shorten the shafts on the lathe, looks like I won't be flying the WKM AD6 anytime real soon.
