Tau Labs Problem wit drifting
Gunter
Draganflyer X4
I have set up my flame wheel quad with a CC board. I have dialled everything in, all settings done and it flies. Problem is that there is always a drift, normally to the right...and it's quite bad. I have enabled it to always zero when armed, then after arming it i leave it for a full 10 seconds before flying (with the props spinning slowly) but that still doesn't do it.
Any other suggestions?
Gunter.
Gunter
Draganflyer X4
Gunter, which mode are you flying at?
And did you do the level calibration?
I have set all modes to stabilised 1. I also calibrated it level on the table and then left it on a level floor when arming. (Tried level calibration a few times!)
DennyR
Check to see if your yaw response is the same to the left and the right. It could be as simple as rudder trim
How much drift are you talking about, and when you say drift do you mean it constantly flies at a fixed angle off (in attitude mode) or what? How many degrees off is it?
Gunter
Draganflyer X4
It is quite a lot of drift, not just slowly but you have to keep the stick hard over to keep it one place. Last night I levelled it up on the bench with a spirit level and reset it, then played with some of the settings. I managed to get it a lot better but occasionally it gets a bee under its bonnet and starts again! It's a bit random at the moment.
Regards,
Gunter.
matwelli
What's your attitude kp setting, default is 0.03, but that tends to cause drift, set to 0.05, its in the menu on the right under attitude stabilisation settings.
G-u-nuts
Hey Gunter,
Is this your only CC that u have??, I have 3 of them and all 3 drift,not as bad as yours, there is not one that i have,that does the same.set it to .05 as Mat said,
That will help sometimes ..
Gunter
Draganflyer X4
Thanks for the suggestions guys. I have just checked the settings I have at the moment and they seem a lot higher than 0.03! See screenshot:
G-u-nuts
Hi,
That is the wrong place, u need to go the the menu and go to AccelKP it will be 0.03 change it to 0.05 , like mat said. I will try to get you a screen shot..
G-u-nuts
Try this.. u need to swap the first two pic..
G-u-nuts
I was hoping that was it for you.. what size of quad?? your setting are allot higher then mine, maybe it is in the settings..
