DJI issue,s
Guest
so no luck in getting the tunigy,s to work..
fine then .....
so its not compatible with turnigy as dji mentioned.
workx ok with herkules , to bad those turnigys are good , i use them on arduino and a HLE6.
quadcopters
Turnigy , Hobbywing and Himodel escs all work fine with the Wookong try a card programmer to see if anything is different .
You may also find if they are not from the same batch they changed the chip in them about a month or so ago and this will cause a start up timing issue.
he was using the turnigy dlux 40 sbec something, seem to be i newer product and maybe not based on the same chip as the plush or on the chip you mentioned to have a start up timing issue.
Guest
Well all work fine now , found it but sorry cant share it
Im a gray reseller and need to help myself
Last post on this form to much politics here, sorry
O yes seems that our friend victor has the hrekules working after cleaning , but didmt somehow mentioned it.
Have fun all...
DennyR
I can confirm the same also Tiger motor ESC work fine. The secret to getting stability in wind with WKM is not found in the ESC. I also will keep that a secret.
Guest
true , but if you get accused , spit on and edit your messages.
one can feel reluctant to share it also.
so in the spirit of support , we will surely help our customers that actually bought and used them.
i seen no reseller here giving any answers just users like yourself..
quadcopters
You obviously havent been looking very well then because I have answered loads of questions regarding WKM even to people that have bought elsewhere , You might also remember i made a post on the Droidworx bulletin board asking if any of you guys could recommend a heavy lift set up when we all got the CS series first release and it had many views but not 1 reply.
I have tried to help you here Sandor with some suggestions same as other members on here yet you throw it back at us.
But if you use some due diligence you will see that myself purchased a test system and played around with it before deciding to sell it , so please do not start throwing mud about because sometimes it can backfire.
There is even a UK member on here who might chip in that purchased a WKM from USA and asked for help setting it up , I gladly offered to help and spent a afternoon helping the guy set it up .
So keep your little secret i am sure the members on here wont be any the worse off .
Sebas600
Mailed you lots of times with questions, never got any responce at all....
Guest
i did answer many questions , but i was to expensive.
and now i am a rip off.
and other claim i am to cheap
so what is it now? :)
Emowillcox
You should have posted up front in your first thread that you would be asking for help on the WKM, but would keeping secrets and not be sharing your result. Then I would not have wasted my time reading a 6 page thread that leads to no answer!
Have fun all...
jffry7
aka TruckBasher
Merry Christmas to all and/or Happy Holidays for those that dont have Christmas...PEACE to all
Sandor be a mate. A friend of mine is having a similar issue. How did you solve it !
Thanks man !
Lanzar
Sandor. My baby cant fly with 3 props only so i will pay u 50 eur (give paypal) if u tell me the solution. U can pm it if u dont want to share it with the world. Would realy like to fly it since its holiday time so be my Santa and pls respond to this post.
lanzar
auevtech
Hello,
I thought you might be interested by this info. I had the same problem with epower 50A esc's. I am deal directly with DJI and the problem is hardware compatibility of your esc's with WKM. Me too M1 was not responding. We bought hobbywing esc's and it solves the problem. So your main controller is working well , they are just not compatible.
I hope that helped, I did not take the time to read all of thsi subject but from what I saw that is your problem.
kindly
Dr Sevilla
Dr. Sevilla,
thanks thats what i was also thinking that some are not compatible at all and wont work. But its a silly one because there has to be something different on port M1 than on the others. DJI should be able to change that. Or if they would finally say make a list which ESCs work and which wont.
But thanks to Sandor who is either giving false information by saying he figured it out or not giving us the answer because he was so mistreated here :) we can keep on looking.
