Knupps from Kristaiansand in Norway
knupps
Hi
My name is "knupps", short for Knut Uppstad.
I was a newsphotographer for many years, but today I work for myself.
Started up with a Gaui 330xs in august 2011 to test out aerial photography and video posibilities.
After a while I buildt a new DIY quadframe.
And I was instantly hooked.... Just love it.
I joined this forum to learn more.
Here are my first flights using my Canon IXUS 220HS
My camera setup
My setup today is:
Quadframe from http://www.infinity-hobby.com/main/product_info.php?products_id=7711
Landing gear and camera mount from http://www.infinity-hobby.com/main/product_info.php?cPath=198_230&products_id=4758
4 Scorpion motors and GU-344 controller
JR XG7 radio
FPV from http://www.lowpricerc.com/product_info.php?cPath=36&products_id=990
View attachment 1720View attachment 1721View attachment 1722View attachment 1723
My current quad.
FPV setup
Look forward to join the discussions on this forum.
Knut Uppstad (knupps)
Jake Bullit
Fly,crash,glue,repeat!
Welcome aboard knupps.
Thats a nice setup you have there.Does your video feed come directly from the Ixus?
Also you seem to have a little bit of oscillation,are your motor mounts stiff enough? did you think about mounting them directly to the frame ?
knupps
Hi, thanks for the comment.
The videofeed is from the IXUS, but I will get a new dedicated FPV camera.
I lost the feed from the IXUS once....................
The new motor mounts are very stiff, but I think the problem is weak Scorpion motors and GU-344 controller.
Mounting the motors on the frame arms is the best option. Will try that.
I also need a cameramount stabilizer.
Therefor I am planning to upgrade to the FlyCam Blackboard Set from http://www.kkmulticopter.kr/index.h...lected=KKMulticopter&sn=flycam_black&id_no=90
and Avroto 2814 Short Shaft motors from http://www.shop.aglhobbiesllc.com/Motors-ESCs-and-Props/Avroto-2814-Short-Shaft.html
Also looking for a good and simple new hexaframe.
Here is the first testflight with my new quadframe.
Hi and welcome to MRF..
Check out the new xaircraft hexa frame for a cheap set up.. its pretty solid build.. Geoff at quadcopters.co.uk has them and has just built one up with a WKM controller on it
Jake Bullit
presume you looked at rustys frame while your buying your motors from him. i just one for a y6 build, but they are configarable from a tri right up to an octo.
Sent from my HTC HD2 using Tapatalk
