I'm finally making progress on my CineStar 6 build. I can't go too far without the motors, but they were shipped today. Basically, they are the same as the QC 3328, with a kV around 700, I think. I also have six HobbyWing 40A Platinum ESCs on there way, so I'm hoping to get them by Wednesday as well. I'm going to start out running a pair of 5s-5000 packs, and see how it does. Initial props will be Graupner 11x5s. Initially, for a mount, I will use one of Andrey Kim's (AskmanAP...) old two-axis CF mounts, modified with a 2:1 belt drive in each axis. Eventually, I'm hoping to upgrade this setup to the CineStar gimbal, but for now, this will have to suffice. I think it will be okay because I plan to use a pair of high-speed, high-resolution Hitec servos and run them on 7.4V, so it should be fairy responsive. The belt drive will smooth out the operation.
Since I can't really swing another WK-M setup right now, I'm going to move the one that is on my X8 over here, and then put something else on the X8. I have a new-in-package XA setup, including the active GPS and compass, that I've had since June. I think what I'll try is just leaving the GPS and compass off until they finally get around to fixing the fatal flaws in the GPS/compass functions. (I stopped holding my breath long ago... :upset: ). I can live without the position hold function, on this platform, but I'll really miss the altitude hold feature, though. Anyway, it seems to have a decent gimbal output implementation, so I can try it with my GoPro mount. I may later switch to the Naza, because it still has altitude hold and the camera outputs.
Anyway I'm taking CS 6 pics as I go, and I'll post them here later on.
-- Gary
