APC slow fly props
DennyR
Bart sometimes high bearing wear can be attributed to having the shaft tolerance too tight in the bearing so that thermal expansion loads the bearing as well as the thrust loads. If they get hot then out comes the lube.
The shaft should be a nice slide fit and not need any force to assemble it. Those Japanese bearings that Tiger use are the best.
SYNDK8
Skyvokker
I think I am going to pick those up as well.
Which model did you get? They have three versions:
1 - Beechwood Propeller
2 - Black Eagle Beachwood Propeller
3 - Beechwood Propeller for electric engines (I guess this one?)
I buy JXF props from himodel.com. Don't know any shop that sells JXF though.
ovdt
Hi SYNDK8,
Yes, you should choose the 3rd one.
