schnellschnell
I am building a quad with a DJI and already have a Spektrum DX7 transmitter. I was looking at getting the AR7100 Rx, is that a decent one, or is there another model I need.
Jason
Jason
Hi Duddy and welcom to MRF..
You have to do two binds with the AR8000. First bind the radio as normal. Then insert the bind plug with the battery disconnected and radio off. Plug in flight battery and then remove the bind plug BEFORE turning the radio on. Now go set the throttle to 40% and you need just one of the positions set to fail safe.
Unplug the battery and reboot the radio.. now go set your switch to your manual Atti and GPS..
When you turn off the radio it should now go to failsafe...
