Yesterday morning turned out to be a perfect for flying, I headed over to the RC heli field early to get some air time before any wind started up. Took WKM #2 along to give it its first flight time someplace other than my front or backyard, this one is a lot of fun to fly in any amount of space as I found out. Did 3 or 4 flights with the quad and didn't want to stop but unfortunately time was limitied with several other multis in the car that's all I had time for on this trip, also had the big hex along as well and did a couple flights with it too. The video is mostly GPS position hold climbing straight up and then some general flying around in ATTI mode before a RTH and autoland seen from the onboard GoPro point of view. For the RTH I flew it most of the way down the field, turned on GPS position hold, then flipped the switch to trigger failsafe and then let the TX hang on the nech strap while I stood and watched. I have to say I was a little bit nervous since I had not yet tried RTH on either of my WKM and wasn't quite sure what was going to happen, felt sort of like the first time I used waypoint flight and come home on the MK Hexa. The amazing thing was by the time I did the RTH the wind had come up a bit but even so the quad autolanded within a meter of where it took off. The painted circle you see on the grass as its landing is where I had put it down for take off and ultimately it wound up just a small distance behind the circle, I doubt that either of my MK GPS would be that accurate!
