Help with Failsafe Set up on Page 12
rwilabee
I have installed and set up the Control Mode Switch (Step 4 Number 1) and that works fine. I'm now on to (Step 4 Number 2) and I just don't get it. Can someone explain to me what should be happening. It says to move the slider to the range which reads Fail Safe Mode to turn the area blue. Am I suppose to change the end points again that I just set up and if so which switch positions do I do it in. This is the last thing to do before I can test fly. I also don't get Set Fail-Safe output of receiver to input port-U.
Rich
Gunter
Draganflyer X4
Rich
Rich, have a look at the top of page 2 here, it may help...
Gunter.
rwilabee
I'm still not getting it. I am using a Spektrum DX8 and I just can't get this to work. Can someone explain simply how to make this happen.
Rich
Rich, there are a number of steps that you will have to go through regardless of the make of radio (transmitter). Mine is a Hitec Aurora 9 but I'm pretty sure the set-up isn't any different...
1) Plug the WK-M into your PC via the USB lead and spark up the DJI Wookong application. Select the Tx Cali page.
2) Turn on your transmitter and operate the 3-position switch that you use when selecting 'GPS', 'Attitude' or 'Manual' mode. You should see the blue indicator move along the Control Mode Switch U slider to the relevant position...ie... GPS for switch position 1, Attitude for switch position 2 and Manual for switch position3.
3) With the transmitter fail-safe setup in mind set the fail-safe throttle position to a minimum of around 10% and then reset the transitter End Point Adjustment (EPA) so the the Control Mode Switch U slider goes to 'Fail-safe' for each of the switches 3 positions.
4) Now go through the Transmitter/Receiver Fail-safe setup routine for the DX8. My Hitec does this in a 5-6 seconds window so ensuring that all is in place is paramount.
5) When complete power off the receiver and then the transmitter.
5) Power everything on again as per normal and reset the EPA settings for your 3-position switch back to 'GPS', Attitude' and Manual.
6) Prove that it all works as designed and planned by placing the 3-position switch in 'GPS' mode and then power off the transmitter...the Control Mode Switch U slider blue highlight should move from 'GPS' to 'Fail-Safe'. This should be the same for 'Attitude' and 'Manual' modet switch positions.
I apologise if this all sounds a bit lengthy and tedious but if things go wrong for your craft up in the air it will pay dividends.
6)prAll
cneradio...d
rwilabee
Thanks David make sense now.
I think I'm going to have to get a different receiver. The one I have doesn't seem to support Preset Failsafes. I'm going to call Horizon Hobbies tomorrow the distributors here in the US for Spektrum products.
