Yes. I'm using that little gadget called, "LiPo Battery Voltage Tester Low Voltage Buzzer Alarm." And yes, you're right. When I bring my quad down and hover it right in front of me I can see the readout. If I throttle up slightly, I can see two cells drop from say 3.65 to 3.59 (or 3.6 even), while the remaining other cell drops to below 3.4V.sorry guys but it's impossible to say if the batteries are at fault without having internal resistance numbers.
<<snip>>
Gary, are you using the battery monitors from HobbyKing with the digital readout or just the alarms? the digital readouts will tell you the voltage of each cell and yes, one bad cell will cause those monitors to chirp.
Yes it would have been nice to see the difference in the IR from when they were new to what they are now. My main charger is a PL6 with 60A E-Fuel supply, great for testing.Shawn,
The best you can do when trying to save money on a charger, IMHO, is to save by using the computer server power supplies (available on eBay) while still buying a high quality brand name charger. Here's a pic of my set-up using two Dell power supplies in series to get 24 volts but with an iCharger 206B. Probably not what you wanted to hear but a low quality charger can destroy your expensive batteries and maybe cause a LiPo fire. I've heard of other HobbyKing chargers lasting only a few charge cycles. The iCharger 306B is about $160 and with the two power supplies it's around $180 depending on what you pay for the power supplies.
Probably not the reply you were looking for, sorry!
That is the sum of all six cells. Highest individual cell on any battery was 6. I'm not real familiar with what is good and bad. I just know it was requested here.That IR seems high. No?
Both my Multistar's have failed with at least one cell in each gone bad. Yesterday, I finally received the iCharger 406duo I've been waiting for for over two months, and once I get the thing figured out I will do IR measurements to see what's up.Wanted to come back to this topic and say that the Multistar 4S 8A are now being used on my quad and they are still flying great. But they are under very little stress with this setup.
I did however just do a flight with dual Multistar 6S 8A 10C on my new large hexacopter and they hardly changed temp at 70 F air temp. I measured the IR before flying them and one was at 23 and the other 28.
@Mactadpole what charger and PS are you using with these?
What do you think of using 2x 10Ah Multistar as opposed to the 8Ah? Only slightly more weight (1189g vs. 956g for the 8Ah). I was playing with the numbers since I could compare one-for-one with the $250 Tattu 10Ah.
I have to be honest, I'm getting a bit worried about your AUW with everything I see you putting on that copter.
I use an old dell tower power supply and two iCharger 106B+ chargers. I just got the iChargers a few months ago and love them. I did see your other post about what you picked out. If you are only ever going to charge 6S batteries it seems like overkill. But I'm also cheap.
