A2 Gps module not upgrading to new firmware
Remoteworks
Hi,
I just downgrade my A2 to firmware 2.1 (arrived with 2.3) Only issue is that it seems impossible to upgrade de Gps module from 0.4 to 20.1
It says the upgrade went ok. But after re-powering the A2 it still says 0.4. Sometimes error @ verifying
Did anyone have the same problem?
Thnx for any help
RW
View attachment 19228View attachment 19229View attachment 19230
Using CS8, Graupner Mx-20. Herkules 3, Tiger kw-10, X 14x5, Iosd mk2
Edit. somehow the images are very small!!
Faulty GPS unit. Send it back and insist on a new one ASAP. DONT be fobbed off by it will have to go back to DJI for checking. If your supplier does not supply you with a replacement by return insist on a refund. This IS a known issue but no DJI dealer will admit it, they will just try and fob you off. Instant replacement or a full refund. If I were you I would insist on a full refund and go buy a WKM.
Remoteworks
Hi Dave,
Thnx for the quick answer. Will contact the dealer asap.
Weird that i only noticed this because of the downgrade. Already tried upgrading the Gps on arrival of the A2 but did not notice that it failed before.
Was almost ready to test some camera gear.
RW
