Thank you, KDE Direct!
I have been using this big quad as a test bed, and as you know if you've read this thread, I'm using the new-ish KDE Direct 35A ESCs. I was a little reluctant to use them when I found out that they have no programmability interface...that they "just work". Well, we all know how that usually ends. :apathy:
I'm happy to say that with my motors (Avroto 3515) and the 6S power, they've been super smooth.
Well, I was bitten in the rear by a problem with the 1.3 vTX and the NAZA GPS the other day, and I had to ditch the copter in a nearby field. A few things happened in the crash...
- the 25mm CF boom holding my camera snapped, and my gimbal's set screws sheared off
- the motor wires that ran through one of the booms were partially sheared off causing a short to the motor (which was fried)
- that short caused some serious heat to propagate back to the hub which caused...
- 3 of the 4 servo wires between the ESCs and the NAZA partially melted
- the red lead to one of the KDE ESCs separated from the ESC
- the CF boom holding the bad motor wires partially melted at the hub
- all four 14" Foxtech Supreme Light props were damaged
I was concerned that all this would be super expensive, but here's the damage:
- lost one motor (I have several backups as these were left over from an octo build)
- lost two CF booms (400mm motor and 300mm camera)
- lost the mini PDB (main voltage was fine, but the integrated 12V BEC was fried)
- lost 4 props
- gimbal is TBD...haven't gotten that far, but I was not that happy with it, anyway, so I may switch over to the Tarot 2D I have instead.
About those KDE Direct ESCs? Amazingly, I replaced all the fried servo wires by soldering new wires to the ESCs, and I made a new + lead for the one KDE Direct ESC that lost its one, and they all work great. Pretty remarkable. The copter's back in the air, although I have the wrong size props on it right now. New props should be here in a couple days.
Thank you KDE Direct for these bulletproof ESCs!
