So my Tarot 650 quad with a DJI NAZA M V2 has had an intermittent issue with the FC LED displaying only green. The problem is no longer intermittent. The GPS, ATTI and Manual modes "seem" to work but I do not get a change to an amber light in ATTI model. It remains as a flashing green light. The flashing green light goes off when switched to manual mode. When I attempt GPS calibration the LED initially is steady green, not amber. If I proceed through both the horizontal and vertical maneuvers, the LED turns off as anticipated and begins to flash green again. When I enter failsafe mode, the light begins to slow flash as one would expect in FS but the light does not turn to amber. It never flashes red on initialization or as it is locking onto satellites so I have no idea how many satellites I have locked.
I have read on other forums where others have had this issue but no one ever responds with a resolution. It is almost as if the FC indicator LED has lost the ability to display amber and red. I suppose it could be a hardware issue with the FC as well. I've tried resetting to default parameters for the FC to no avail.
Has anyone on the forum encountered this? I'd sure appreciate any insight.
