genesc
These items I have picked up from recommendations in my posts from you guys. I am attempting to build my first Quad that will be stable enough to learn on. If there is anything I have left out or should change, I would appreciate it if you could pass on the correction to me so I can re-order or add to my order.
This build is based on the Group Build by Bartman
Gene
1 - FrSky 2.4GHz ACCST TARANIS X9D Digital Telemetry Radio System
1- FrSky X8R Rx - 8/16 channel, Sbus, Smart Port Receiver with PCB Gain Antenna
1 - DHI Flamewheel F-450 fame
2 - 2ea. 4 cell 3000ma batteries
1 - iCharger 106B-plus 250W 6s Balance/Charger + Power Supply
4 - 4X SUNNYSKY 2212-980KV Brushless Motor ,Multi-rotors "Not the knock offs"
1 - 2 sets of GemFan 9x4.7 Props
1 - DJI NAZA-M LITE Multi-Rotor Stabalization Controller
4 - Afro ESC 30Amp Multi-rotor Motor Speed Controller
1 - NEW Dubro Tru-Spin Prop Balancer 499
1 - Weller wes 51 Sodering Iron
1 - Kessler 1lb Rosin Core .031 dia. soder roll
1 - 2 packs of small 4" cable ties
1 - Assortment of shrink tube
1 - Two sided 3m tape
1 - Moongel Drum Damper Pad
Gene
