Complete DJI F550 HEXA FPV system INCLUDES field charger / batts and GOPRO3 blk
dma251
Complete DJI F550 HEXA FPV system INCLUDES field charger/bats and GOPRO3 blk
I'm getting outta this hobby, as it seems I enjoy the building and setting up of these devices, but I never seem to enjoy just flying and using them. Time to go back to simpler and cheaper hobbies.
I built this F550 and flew it carefully a dozen or so times. Then I decided a few months ago I needed a field charger system with new batteries, so I built the case-mounted charger/power supply.
It comes with everything listed and shown in the pics. - It has an Orange 8ch flight control RX with Spektrum-DSMX satellite receiver on one of the arms. I am using it with my Spektrum DX8, but I am not including the remote.
It's all gotta go, and I'd like to sell it all together. Here's the list.
Feel free to ask any questions you have. I am an honest seller with an excellent rating from transactions from this site. I will carefully package and quickly ship it out.
$1500 for everything shipped USPS insured within USA.
DJI F550 HEXA Flamewheel frame
DJI NAZA V1 with GPS flight controller (includes extended USB cable adapter)
XAircraft 2216 motors / XAircraft 10/4.5 propellers (w/5 spares props)
AKE AKE8S3512SCT 12amp ESCs
ImmersionRC 5.8gHz 600mw video transmitter w/skew-planar antenna set
[FONT=&amp]PZ0420 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera w/2 lenses (2.1mm/2.8mm) Remote programming control[/FONT]
[FONT=&amp]FATSHARK Dominator video headset with 5.8gHz RX w/battery[/FONT]
[FONT=&amp]Philips PD 9017 9” video monitor[/FONT]
[FONT=&amp]Skylark Tiny OSD III with GPS and Current sensor (includes USB programming adapter)[/FONT]
[FONT=&amp]Amber/blue LED tape night lighting[/FONT]
[FONT=&amp]Airframe – 2011g (including bats)[/FONT]
[FONT=&amp]Tall CF/alum landing-gear - 226g[/FONT]
[FONT=&amp]AUW w/gear and Gopro 3 – 2420g[/FONT]
[FONT=&amp]Avg flight time with 2x4000mah bats - 10-12 minutes[/FONT]
[FONT=&amp]CHARGER/POWER SUPPLY CASE SYSTEM[/FONT]
[FONT=&amp]8 Turnigy Nano-Tech 4000mah 25-50C LIPO batteries (4 months old, 5-10 cycles of use each)[/FONT]
[FONT=&amp]FMA Cellpro PowerLab6 1000 watt charger[/FONT]
[FONT=&amp]2x Dell poweredge 1850 24volt 550watt (1100watt combined) power supply(s)[/FONT]
[FONT=&amp]Power supply voltage and amperage gauges (A&M Intruments)[/FONT]
[FONT=&amp]Separate voltage checker included[/FONT]
[FONT=&amp]Separate removable power-cable[/FONT]
[FONT=&amp]6–place 12awg fused parallel charge / balance cables with APP/Sermos (Anderson Power Pole) connectors[/FONT]
[FONT=&amp]Pelican-Storm IM2300 case w/aluminum rails for resting airframe in field. (18.5” x 13.5” x 7”)[/FONT]
[FONT=&amp]Home-made lightweight plywood storage/travel case with 2” Velcro airframe cinch-down straps (25.5” x 23” x 8.5”)[/FONT]
[FONT=&amp]Gopro3 Hero black camera with clear housing and mounting parts (housing has had holes for microphone access drilled in it but reseal-able with flaps of 3M tape)[/FONT]
[FONT=&amp]16gb Sony micro-SD memory card[/FONT]
dma251
Here's a couple other pics of the led lights on when I fly at night. You can have the front amber or the mid/rear blue on or off individually as they each have JST plugs that just plug into a 3-way JST female battery-voltage bus. video also plugs into this bus.
Everything is soldered to the lower frame board power distribution system. The OSD current sensor is soldered via short lengths of 12awg silicone wire to the board, and then tails out to two separate 12awg parallel battery cables with Anderson Power Pole connectors.
dma251
some better pics
dma251
I don't really know what shipping charges would be to London, but I've listed the exterior dimensions of the two cases, and the charger case weights 23lbs, and the bigger wooden case with everything in it weighs about 20lbs.So you might be able to get a close approximation with that info.
I'll wrap cardboard around each case when I ship. I will cover the first $50 of whatever international shipping is.
dma251
I'm going to offer some of these components for sale seperately.
The charger system is sold (pending)
Fatshark goggles and 9" LCD monitor - $400 shipped USA
Gopro Hero3 Black with housing and 16gb - $275 shipped USA
Hexa airframe with batteries and case (everything else) - $650 shipped USA
dma251
Yeah, its time. I sold the charge case. It was quite a compliment considering how much interest I had in it. Well I built the HEXA with the same attention to real-world AP needs and attention to detail.
Here's the breakdown.
Complete airframe with case, 8 4000mah bats, video camera and tx, Naza GPS, OSD, landing gear, two removable camera mounts, and the spares. (Basically everything you see except the Gopro, goggles, and monitor) --=- $650 - shipped USA
Gopro Hero 3 BLACK with clear case and 16gb Sony memory card --- $250 shipped USA
Fatshark Dominator v3 video goggles with Fatshark 5.8ghz rx and battery -- $315 shipped USA
Philips 9" LCD monitor -- $50 shipped USA
