NAZA Stabilization
Hello,
I am working to get my copter as stable as possible. The link to a video shows how it flies and I am working to fix what seems to be the yaw axis movement.
Any suggestions would be greatly appreciated!!!
Thank you
https://vimeo.com/89574057
Setup-
DJI F550
Running 14.8v 4500mAH 4S 30C Battery
My gains are:
170-pitch
170-roll
150-yaw
140-vertical
170-att pitch
170-att roll
DJI NAZA M
NAZA Version 2 GPS
Zenmuse H3-2D Gimbal
DJI motors- DJI 2212 Brushless Motors,KV: 920 rpm/V
Props- DJI 1038 10" 3.8" pitch
I am not sure on my AUW
mangoats
In the first part of your video, your descending.......... this is the hardest thing for a flight controller to maintain in stability. If you descend straight down you'll see small wobbles from the controller working very hard.. The best way to descend is at a slight angle forward, that way the prop wash is a little behind the vehicle.
Once you come to a hover you have a slight nod to the left and right. I believe that this can be tuned out, going to take some testing with different gains. You should only change one gain at a time. Start with yaw..........
This is just where I would start, others will chime in and help out.
Another thing is, you have a light vehicle and this might be outside of the range for better stability. Mass equals stability.
Your also running the larger props for lift, did you try they 8 inch props to see if it helps? The 10 inch props could cause the vehicle to be over sensitive if it's to light. Just a thought, never hurts to try.
Chris
