Parachute recovery system ideas?
I was remembering the ballistic recovery chutes we had on our ultralights. I wonder if there isn't some way to make a light remote deployable parachute for our multi's. I realize packing a 2+ meter chute would be space consuming, but with enough money on board one would wonder why "we" havent tried this yet.
Any ideas?
There are obviously issues. Another reason bigger is better in my mind. This is just one major thing missing from multis. This could be our auto rotation equivalent! I dont think attitude would make much difference unless it was upside down and the chute got stuck on a prop. But the nice thing is the props have no mass so they wouldnt harm the chute if they were powered down. I bet if someone made it look pretty they would sell.
Efliernz
I think the important goal is treating the chute as a drag-chute / minor damage / no one gets squashed type device. Too big and "floaty" makes it a big device that may get blown a distance. A smaller chute slows the craft down while it still descends straight down. Perhaps 60" / 4lbs. I haven't done model rockets - just reading...
I have put some thought into this idea over the last 6 months - please comment / pick-to-pieces at will ;)
A small high(ish) tension spring to assist launch. Two servos lock the chute loaded in place. If the servos were Y-leaded (or separate rx) off the throttle and another switch, it could not be fired without the throttle being down/closed and another switch hit. The chute needs a 3' nylon lead as minimum to clear any concern over tangling with a tumbling machine.
jes1111
This is the only off-the-shelf system I've found that would be easily adaptable to a multirotor: http://www.the-rocketman.com/model-recovery.html
I agree you'd want an interlink system to cut the engines before deployment. I've also thought about the idea for a long time and keep coming back to it. But in the end it just doesn't add up for me on weight (potentially about 500+g for my craft's weight), lack of control, etc. - I resolved to spend the equivalent effort and money on making sure the craft doesn't need rescuing in the first place ;)
Gunter
Draganflyer X4
I have spent ages also thinking about something like this as well! Ideally, one switch would cut the motors and deploy the chute a split second later.
I also thought about an air-bag system, one deploying underneath and one above, like 2 big donuts...also make them so that after deploying, the air stays inside and it acts as a float if it lands in water. (in a normal air-bag, the air escapes pretty quickly after deployment)
Crash
Defies Psychics
I've been thinking about this off and on for the last 18 months. I even bought a few small chutes to test with. Various methods have been attempted by others with varying degrees of success.
My idea is to use a spring loaded carbon shaft with a chute connected to the end. A servo would release the shaft which would pull the chute away from the quad. (Kind of like a pole vaulter.) A round ring would hold the chute somewhat open for a quick deployment. I think the shaft would help to only allow the chute to deploy at the correct attitude.
I was going to test this on a spare frame then I forgot why I was saving the frame and I sold it. :eek:
I took the pictures below a long time ago and they aren't very good but maybe they will help a little though.
The chute came from here: http://aeroconsystems.com/cart/products/36_inch_white_parachute-56-2.html
About 40 grams and $6+shipping.
