trying to use ch 9-14 with 14sg
cyborg
I have futaba 14sg with r7008sb receiver. I also have naza m lite that does not work with the r7008sb in sbus mode. I bought frsky tfr8sb that work fine in sbus mode with the 14sg. I can't get the tfr8sb into mode B so I could use ch 9-14 with sbus.
I decide to use the r7008sb as the second receiver for ch 9-14. In the fastest mode the r7008sb connected as the second receiver on ch 9-14 but at the same time lost connection with the frsky tfr8sb because that was a fasst receiver.
I order another tfr8sb. If I replace the naza m lite with naza m v2 then the r7008sb will work with that receiver. That would be a expensive option.
I am going on vacation in 3 weeks and I wanted to take my hex. I also received my tarot 2d gimbal yesterday and it was missing the hard ware packet to assemble the gimbal. I have a camera switch, a multi switch for lights and I want to control the gimbal . This is why I need the other channels. Any advice would appreciated.
PeteDee
Mr take no prisoners!
You can just use the 7008SB as a standard S-Bus Rx for channels 1-14 just set it as mode D, you can use 9-15 for whatever you want using a traditional connection.
I have mine set to mode A and control A-E-T-R, mode and IOC through S-Bus and pitch of my gimbal and camera switch via channel 5 and 8.
PeteDee
You have the choice of S-Bus or S-Bus2, you must use S-Bus, who told you it will not work?
cyborg
Firmware upgrade fix it for naza m v2 but not for naza m litehttp://www.multirotorforums.com/showthread.php?9661-R7008SB-S-Bus-with-NAZA/page2
cyborg
I was trying to link to a 6 pg thread in this forum. The thread explained it. This is why I'm using the tfr8sb receiver
PeteDee
Apologies my mistake here, appears the 7008 does not work with Lite. It does work fine with M though.
PeteDee
Time for an update for the Lite please DJI or are you too busy driving around in all your Spaghetti Veyrons?
cyborg
The second tfr8sb receiver I bought does not solve my problem. First I can't get either of the tfr8sb receiver to switch to mode B. Second the 14sg can do dual receiver only if using two fasstest receiver.
I was struggling with this issue for over two weeks so I decide to order a naza m v2. I will use the lite for a future build of a quad.
