Pete,
I asked a bit ago in another thread about why you aren't fond of Spektrum TXs......can you elaborate? Also, why is DSM2 NOT a good format? There are a TON of guys that still use DSM2 around where I live and even with 10 or so of them flying there hasn't been an issue.
Cheers,
Mike![]()
I answered in the other thread and I am fond of Spektrum, love my DX18, just not so much for MR's and FPV.
I just got Spektrums converter kit for my older Futaba 9C "SPMMSFUT720 DSM2 8 channel" It looks nice, comes with a AR7010 receiver and the little remote receiver. All for around $100.
Am I wrong or does the old 72 radios have more range than the 2.4 stuff?
Question of the ages. With 40+ years of RF industry experience behind me, on the surface of it, I'd say yes. Power levels are higher and the instantaneous, per-symbol, bandwidth is about the same. But...., all the tests I've seen tend to indicate only just slightly so. Most of the 2.4 systems seem to hit 2-3 miles under typical slant-range conditions and most of 72 systems hit 3-4. Not much difference. I, personally, haven't tested this, so I hestiate to say anything absolutely. If you need reach, go with any one of the popular LRS systems out there. The operate near the bottom of the 70cm Ham band and do require a Ham licence to operate legally, but the reach is there. Double digit miles are routine. Using specialized antenna systems, I recently saw videos from a Mexican group operating a fixed wing aircraft at *48miles*, with a Dragon Link brand set up.
4xx Mhz should do the distance with some high dB gain antennas especially a Yagi on the RC Transmitter
And there is also the 900Mhz fhss which I use with my DJI Ground control station suitable to 10km + especially with higher gain vehicle roof mounted omni. VE6GLT
