srbell
Anyone else have trouble balancing propellers? It seems my old trusted Dubro units have way too much friction to balance the newer light weight props and the magnetic balancers seem to have a lot of trouble with strait shafts. It was obvious with the Dubro's wheel setup it wasn't going to work but I was surprised how poorly the TF magnetic units worked. Seems with the soft steel shafts you're guaranteed it won't be true. I've ordered a half dozen more with the same results. You think it's balanced and then turn the prop 180 on the shaft and it's way out of balance. There's got to be something more accurate out there. Anyone? It would be nice of it could accommodate up to 26" propeller as well. I cut my TF sides in half and added some carbon square tubes to extend to 22"
