DJI SBUS converter
Hi Is any one using the SBUS converter. I though I may eventuly get on of the A2 paper weights flying with one and a Spektum AR9020 receiver.
SO I follow the very short useless instructions and to my surprise it worked.. well sort of.
SO now the problems.
I can't get the unit to go to fail-safe when TX is turned off (Help!)
I can't assign a channel for POI (HELP!)
I can't assign a channel for come home switch. (HELP!)
Basically when you click the box to set up POI the channel assign assistant comes up. You select the channel but as soon as you close the window the box you ticked unticks itself.
I am going back out there to spend another evening trying to work it out so any help would be appreciated.
Dave:livid::livid:
So I got the Failsafe and POI switches sorted.. doh just was so strung out trying to get this thing up I did not see there was designated channel assignments!
NOW just need the copter to go to failsafe return to home when it looses the TX signal
