Mactadpole
Well after my successful maiden flight last night I wanted to do some more flying today. But of course it was windy (10-15mph). I went ahead and walked to my little flying spot with pockets loaded with batteries. I had set my Gyro-P and Gyro-I to my knobs/dials on the tx so I could do some tuning. Everything was at stock values. The heavy-lift X8 flew well but was experiencing a lot more wind induced drift than I had experienced when flying with the HFP FC. It required near constant input to keep from drifting. I tried upping the I value but have now read I probably should have been lowering it. I also played with P-value some as well. I really did not notice much of a change in flight characteristics. I went from 100 to 132 on P and 120 to 177 on I. I also read that I should try lowering the dynamic stability. How do I go about getting it to hold itself against the wind better?
Also, on the maiden flight last night I noticed that if I landed and stopped the motors from spinning and then started them up again they would not all start at the same time. It worked fine on the bench, but after a few minutes of flying outside it starts. So, I upped my min gas from 14 to 16 for todays flights. Sure enough it was doing the same thing and it was a little worse after a couple flights. I am going to do the esc calibration procedure on the I2C converter and up the min gas value by 2 again. Any other suggestions?
Shawn
Shawn
