Update 5.24
boranup
It allows the motors to rotate so you can check motor direction to ensure all props rotate the correct way. The only rotate one motor at a time and only for a split second, but enough to determine rotational direction
boranup
When you go into the software and click on motor test a pop up box comes up after you agree to the disclaimer to remove props - then you just click on the motor you wish to test.
