Mikrokopter Mk3638
edykosta
Hey, has anyone ever tried using the mk3638 engines with other esc other than the mikrokopter ones...planning a build and wanna use the hk 30a escs that I have with these. Thanks
Edy
I believe those motors are rebranded Tiger 2814 motors in which case a 40A ESC would be recommended with 4S batteries. The motors should be fine with the standard chinese ESC's that are commonly available.
Bart
sas
I was always under the impression they were made by Pulso - either way they're very good :)
One of my machines uses these with Hoverfly controller and 40A Hobbywings on 4S and is extremely athletic.
SamaraMedia
What size props do you plan to use with these motors? Looking for recommendations for similar build?
John
i've used 12x6 APC and 13x6.5APC without problems.
Thread is a month old but why not? I swing the new APC 16x5.5MR props with my 3638's. Flies very nice. Total weight with Blackmagic Pocket/14mm lens, 3-axis, and 2x6500maH batts= 5000g. MK stack. I have barely enough room to swing the 18" props, might experiment with those.
