Replaced Naza v2 with Wookong No motor arming HELP
iflynavy
Hello all
I have an x650 Pro modified that previously had a NAZA v2 Installed. I just recieved my Wookong, went ahead and installed it.
I calibrated the compass, and restarted the Quad. Lights are flashing with the GPS status, then the mode (i.e. purple GPS, Yellow for ATTI).
However the motors won't arm. I took it back inside plugged it into the Assistant, did a motor test and all was fine. Each motor spun for about a second or two and all looks fine.
What am I missing, or what is going on?
I have DX8 Spectrum with an AR8000 reciever and have verified all controls in the assistant.
Please help
Carapau
You probably have channels reversed so have a look at the TX cal screen. On the throttle and elevator sliders, if you push these sticks forward on the TX the sliders should go right. If these channels are wrong then your combo stick move wont be arming the WKM properly
iflynavy
Yeah figured that out yesterday just before you posted ;) Thank you though these forums can be a life saver, at least it's out there for someone else now
