Hexa, Will it fly?
alvinrenz
I am about to order this hexa parats today, im not sure if i did it right on the eCalc but what do you think? can this fly smooth? or will this even lift from the ground?
has anyone have used the Turnigy 2217 16t 1050kv?
Flight control: kk2.0 1.2
Motor: Turnigy 2217 16t 1050kv
ESC: 5x HK F30 simonK flased
Frame: original DJI F550
battery: Turnigy 3600mah 3S 20C
prop: SF 1045 SF1045 RH
Radio: Turnigy 9x mode 2 w/ module and receiver
MISC ITEMS:
voltage meter with alarm
Charger: turnigy accucel 6
5.6mm x 18mm M3 Nylon Threaded Spacer
Battery Strap
Breakout cable
10x 3.5 Gold connectors
USBASP AVR ATMEL PROGRAMMER for KK2.0
That is all i have for this build I'm not sure if miss anything. is there anything i need more? this going to be my trainer quad and planning to move to a bigger Frame in the futre:)
here is a screen shot of eCalc, everything looks fine. ITHINK::confused:
tstrike
pendejo grande
Check your all up weight again, with the motors and esc's you listed I get almost 600 grams from just them. Looks like you just put the bare frame weight in there and forgot about all the other things you have to lift.
alvinrenz
on the eCalc it say drive weight is 1053g i think this is the motor,esc and battery. and the frame weight without the drive is 478g. all up weight is 1531g. if i am correct with the calculation.
