XAircraft return home and newest software vor version 1 the S one
paktazh
Hi is there any return home option with Version one xaircraft with the GPS The S version thanks
djbuzzard
No, the return to home feature is only available with the version 2 P version. I have the Version 1 with GPS and it is not available in the settings menu.
paktazh
Hi Bro
Is there any good software set up for v1 I tried to fly it it either flip or if it left off it go fast to one side the care free option does not work as i see the software give u lots of other option like heading lock and show lamp I could not set those in software and the GPs mode is not holding position eventhough it was in GPS it left off once and and it was keep going uncontrolable any solotion or a good video thanks
paktazh
Sounds like the radio settings need to be checked. Did you do a receiver calibration?
The Rx was OK but in the software i had to select high and marking the high in front of each one then it make them work I understand the work of head lock but couldn't find any video about the care free there was one video in vimeo but there was one and that was in chines any idea how the care free works in xaircraft thanks
djbuzzard
I have the same channel selecting carefree and heading lock because I don't need them on at the same time. It's up to you how you assign those channels. The most significant setting for me was the ATT and GPS modes, which are set on a three-way toggle switch on my radio (Turnigy 9X with 9XR) Not sure what else you need to know. BTW, did you contact Xaircraft? They responded to me quickly when I first had some issues configuring my radio. To be honest, they have lost some traction here on the forums due to bad press (and you won't have too much help) but the system works fine if all is configured well. I bought mine before reviewing other folks issues and had to do my research. Basically, the link I provided you and contacting Xaircraft directly, you should get your issues sorted out. If not, you may have defective gear and I don't know how anyone would be able to confirm that here...there may be some more knowledgeable folks on this platform but the best path is to contact the manufacturer directly.
paktazh
+thanks Bro but everything works good in the software now and I set the the care free and head lock but i did not understand what the care free is for what job does it do I donot know what gain u used but mine keep flipping and in Att the motor one get lots of power and in manual motor 4 I copied all the gain setting from that site u give me but stilll no luck just wondering what gain is yours thanks
this my gain settingStick Gains Pitch – 36, Roll – 36, Yaw – 36
Attitude Control Gain Pitch – 30, Roll – 30, Yaw – 25
Auto leveling gains Pitch – 40, Roll – 40
GPS gain – 30
Height gain – 35
djbuzzard
Sounds like you have something mixed up on the motor connectors...I used the gain settings that were suggested in the link(don't have my laptop right now to confirm but I think you have the same settings I have if you used the ones from the link)
Check this video also...https://vimeo.com/37885973
Have you tried holding the quad in your hand and checking that it is responding to your radio correctly? Be careful...but that's how I check once I have the blades on right before flight. My dyslexia has been a problem before dealing with this hobby, LOL.
