No, the return to home feature is only available with the version 2 P version. I have the Version 1 with GPS and it is not available in the settings menu.
You first should fly it without the GPS or Compass connected to ensure you have the AHRS and FC calibrated correctly. Once you do that then connect everything, recalibrate and try it. Refer to Xaircraft's Wiki and also here: http://www.rcgroups.com/forums/showthread.php?t=1670862
Thanks Bro is there any video available for setting it up since there is lots of information and video for dji but nine for this
Just do a search on Vimeo...Xaircraft has most of their videos uploaded there. https://vimeo.com/xaircraft
Thanks Bro do u know where to install the GPS do u have to do measurement like the DJI from the IMU to GPS or it does not matter
could not set the head lock in the software I did assaign a switch to it which is ch 7 but it does not turn on in the software any idea Thanks
Sounds like the radio settings need to be checked. Did you do a receiver calibration?
I have the same channel selecting carefree and heading lock because I don't need them on at the same time. It's up to you how you assign those channels. The most significant setting for me was the ATT and GPS modes, which are set on a three-way toggle switch on my radio (Turnigy 9X with 9XR) Not sure what else you need to know. BTW, did you contact Xaircraft? They responded to me quickly when I first had some issues configuring my radio. To be honest, they have lost some traction here on the forums due to bad press (and you won't have too much help) but the system works fine if all is configured well. I bought mine before reviewing other folks issues and had to do my research. Basically, the link I provided you and contacting Xaircraft directly, you should get your issues sorted out. If not, you may have defective gear and I don't know how anyone would be able to confirm that here...there may be some more knowledgeable folks on this platform but the best path is to contact the manufacturer directly.The Rx was OK but in the software i had to select high and marking the high in front of each one then it make them work I understand the work of head lock but couldn't find any video about the care free there was one video in vimeo but there was one and that was in chines any idea how the care free works in xaircraft thanks
