Cheshirecat
OK thsi is probably Coax 101 type stuff but despite searching around and even watching other peoples videos in slow mo i can't quite get the definitive answer i am confident with.
On an X4 what is the correct rotaionional layout betwix top and bottom props :confusion:
I have figured that the high pressure side of each prop is always down and that the botton motor would rotate in the same direction, mechanically albeit upsidedown so counter rotating looking down on the rig, but the prop would have it's leading edge on the otherside (counter) so effectively it's lift is the same.
So in essence the top prop is the reverse of the bottom prop and the motors rotate (mechanically in relation to themselves) in the same direction.
Then would every other boom be the reverse of the previous boom setup. So Boom 1 say Top Motor CW Prop Bottom Motor CCW Prop - Then Boom 2 Top Motor CCW Prop Bottom Motor CW Prop????
Crickey :upset: i wonder how right or wrong any of this is, maybe i should use rockets instead.
