AV200 + RSGS Nick move Roll..
marioka
Hello
I bought AV200 with RSGS. I have now this problem: When I'm moving Nick then the Roll-Axis move a little bit too. Have someone the same problem?
ATFlyer
When you "SET LEVEL" on the RSGS Tuning page make sure that the RSGS is perfectly level (not necessarily the tray) for the X & Y axis and then exactly vertical when you point it looking down to set the Z axis. The closer to perfect this process is has a huge effect on nick/roll coupling on mine.
good luck!
When you set level, do it with radio on, no trims, no subtrims, proceed to the autotune WITH your camera perfectly (as possible) balanced .
