I do understand that from the customer's perspective, a server issue is   indistinguishable from a software issue; I only meant to point out that  there is a difference between the two "under the hood." (Also, I should've used the word  "product" rather than "technology."
There's no  "shifting blame" involved or intended. Any networking professional will tell you that server downtime is  unavoidable; the best you can hope for in the long run is to minimize  it. Of course, two occurrences within about a month probably does  warrant us taking a  look at our current arrangement and seeing if there  is a better option.
Jeff: I understand your points, but as I see it, having a downloadable executable  would only make a difference if you were reloading firmware that you  already had. New firmware would still require you to connect to a server  and download the executable (or update it). I really don't see how that makes an  appreciable difference in the issue of server reliance. Explain please?
