Do you like Mk flight controllers but don't like being locked into using I2C controllers with it? There's a great way to fix that problem for not a lot of $, http://abusemark.com/store/index.php?main_page=product_info&cPath=1&products_id=3
After building my X8 project using standard Turnigy Plush ESCs I wanted to try flying it with an Mk controller but there was no way I was going to spend the $$$ for 8 BL controllers. While surfing other sites I came across a thread on the Precision converter as well as one from a website in France. After a bit of research it looked like the Precision was the better board and it certainly cost a lot less as well so I ordered two of them, came to less than $35 delivered.
Today I finally got a chance to set it up on the X8, pretty simple really. Solder wires with a servo connector to the I2C pads and ground on the bottom of the MK F/C, set the converter for the number of motors by bridging pads on the bottom similar to setting the address on a MK BL, then connect all the ESC wires to the converter (power to the converter is supplied via the BEC on the number 1 ESC). Use a Spektrum bind plug on the converters I2C connection on the first power up to calibrate the ESC's, power down and connect the I2C lead from the F/C and you're done, that's all there is to it.
Seemed too easy to me so I made sure to take all the props off and give to a thorough bench test before attempting to fly but it appeared to work perfectly so I put the props on, went out in the backyard, started the motors and lifted it in the air. Worked exactly the same as any Mk, I couldn't see any difference in how the motors ran or how it flew. Only thing I did notice was some of the motors stopped spinning after landing before I did a shutdown. That concerned me a little so I restarted the motors and lifted off again, of course all the motors stayed running on the next landing! After a couple tries I was able to reproduce the motors stopping on their own so before using the motor shutdown sequence I gave it some throttle and the stopped motors spun up again so I don't see that as being a problem at all.
Overall this may just be the best $15 I've ever spent on an MK!
