GoPro ISO - wire frame isolation for GoPro and other jello monsters.
Breezemont
WARNING!
SOME ASSEMBLY REQUIRED.
1) The ClikIt ISO Pro:
$29 shipped CONUS
**Int'l is $38 shipped
Canada is $35 shipped
This fully adjustable modular design is completely compatible with the GoPro quick release clip system.
Included in the kit:
1/4-20 (tripod mount) endplate with female clip bolt pattern
6-32 mount endplate with male clip bolt pattern
(5) 3mm nuts and bolts for clip mounting
1.2mm wire rope precut with ferrule and adjustable cable stop
1.27mm hex key
Also available in HiViz Green!
Loose tension:
Tight:
2) The Barebak:
$27 shipped CONUS
Int'l is $36 shipped
Canada is $33 shipped
Designed for those who like to go light and risky!
(3) 3mm nuts and bolts for clip mounting
1.27mm hex key
20 grams
3) The Hex:
$27 shipped CONUS
This is heavy-duty hex-shaped has holes for 6 captured #6-32 hex and either 1/4-20 or #6-32 in the middle.
Works well for larger cameras.
30mm diameter
24 grams
1.27mm hex key
Strength test:
DJI Phantom pilots: we're thinking about you too. <-- Click
PLEASE NOTE:
These are hand-crafted and 3d printed items and as such are prone to cosmetic blemishes and subtle differences. I haven't figured out how to make a machine that can put them together yet... :D
Click here to email me for PayPal info, please. The PM system here is too hard to use for this.
